Perfect Sampling of Networks with Finite and Infinite Capacity Queues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ana Bušić
Bruno Gaujal
Florence Perronnin
We consider open Jackson queueing networks with mixed finite and infinite buffers and analyze the efficiency of sampling from their exact stationary distribution. We show that perfect sampling is possible, although the underlying Markov chain has a large or even infinite state space. The main idea is to use a Jackson network with infinite buffers (that has a product form stationary distribution) to bound the number of initial conditions to be considered in the coupling from the past scheme. We also provide bounds on the sampling time of this new perfect sampling algorithm under hyper-stability conditions (to be defined in the paper) for each queue. These bounds show that the new algorithm is considerably more efficient than existing perfect samplers even in the case where all queues are finite. We illustrate this efficiency through numerical experiments.
Fichier non déposé
hal-00788003 , version 1 (13-02-2013)
Ana Bušić, Bruno Gaujal, Florence Perronnin. Perfect Sampling of Networks with Finite and Infinite Capacity Queues. 19th International Conference on Analytical and Stochastic Modelling Techniques and Applications (ASMTA) 2012, 2012, Grenoble, France. pp.136-149, ⟨10.1007/978-3-642-30782-9_10⟩. ⟨hal-00788003⟩
225 Consultations
0 Téléchargements
