Pattern-Based Approach to Table Extraction
In this paper, we address a client-driven approach to automatically extract information content within the table in document images. We start with a graph-based representation of a set of key-fields selected by clients and perform graph mining in a document in order to learn them to produce a model. Such models are aimed to use to extract information content in the absence of clients. To avoid NP-hard general problem, our graph matching is based on relation assignment to see whether pairs of nodes are semantically identical. We have validated the concept by using a real-world industrial problem.
