Regular expression constrained sequence alignment revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Biology Année : 2011
Imposing constraints in the form of a finite automaton or a regular expression is an effective way to incorporate additional a priori knowledge into sequence alignment procedures. With this motivation, the Regular Expression Constrained Sequence Alignment Problem was introduced, which proposed an O(n^2t^4) time and O(n^2t^2) space algorithm for solving it, where n is the length of the input strings and t is the number of states in the input non-deterministic automaton. A faster O(n^2t^3) time algorithm for the same problem was subsequently proposed. In this article, we further speed up the algorithms for Regular Language Constrained Sequence Alignment by reducing their worst case time complexity bound to O(n^2t^3/log t). This is done by establishing an optimal bound on the size of Straight-Line Programs solving the maxima computation subproblem of the basic dynamic programming algorithm. We also study another solution based on a Steiner Tree computation. While it does not improve worst case, our simulations show that both approaches are efficient in practice, especially when the input automata are dense.
CMB-2010-0291-Kucherov_1P.pdf (381.06 Ko) Télécharger le fichier
hal-00790008 , version 1 (19-02-2013)
Gregory Kucherov, Tamar Pinhas, Michal Ziv-Ukelson. Regular expression constrained sequence alignment revisited. Journal of Computational Biology, 2011, 18 (5), pp.771-781. ⟨10.1089/cmb.2010.0291⟩. ⟨hal-00790008⟩
309 Consultations
637 Téléchargements
