Distributed tree decomposition with privacy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Vincent Armant
Laurent Simon
  • Fonction : Auteur
  • PersonId : 830497
Philippe Dague
Tree Decomposition of Graphical Models is a well known method for mapping a graph into a tree, that is commonly used to speed up solving many problems. However, in a distributed case, one may have to respect the privacy rules (a subset of variables may have to be kept secret in a peer), and the initial network architecture (no link can be dynamically added). In this context, we propose a new distributed method, based on token passing and local elections, that shows performances (in the jointree quality) close to the state of the art Bucket Elimination in a centralized case (i.e. when used without these two restrictions). Until now, the state of the art in a distributed context was using a Depth-First traversal with a clever heuristic. It is outperformed by our method on two families of problems sharing the small-world property.
main-token.pdf (433.59 Ko) Télécharger le fichier
hal-00790112 , version 1 (19-02-2013)
  • HAL Id : hal-00790112 , version 1
Vincent Armant, Laurent Simon, Philippe Dague. Distributed tree decomposition with privacy. CP - 18th International Conference on Principles and Practice of Constraint Programming, Oct 2012, Québec, Canada. ⟨hal-00790112⟩
68 Consultations
559 Téléchargements
