Place Recognition via 3D Modeling for Personal Activity Lifelog Using Wearable Camera - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hazem Wannous
  • Fonction : Auteur
  • PersonId : 928010
Mohamed Daoudi
In this paper, a method for location recognition in a visual lifelog is presented. Its motivation is the detection of activity related places within an indoor environment to facilitate navigation in the lifelog. It takes advantage of a camera mounted on the shoulder, which is pri- marily designed for the behavioral analysis of Instrumental Activities of Daily Living (IADL). The proposed approach provides an automatic in- dexing of the content stream, based on the presence in specific 3D places related to instrumental activites. It relies on 3D models of the places of interest that are built thanks to a lightweight semi-supervised approach. Performance evaluation on real data show the potential of this approach compared to 2D only recognition.
Wannous-MMM-2012.pdf (553.49 Ko) Télécharger le fichier
hal-00790823 , version 1 (21-02-2013)
  • HAL Id : hal-00790823 , version 1
Hazem Wannous, Vladislavs Dovgalecs, Rémi Mégret, Mohamed Daoudi. Place Recognition via 3D Modeling for Personal Activity Lifelog Using Wearable Camera. International Conference on Multimedia Modeling, Jan 2012, Klangenfurt, Austria. pp.244-254. ⟨hal-00790823⟩
170 Consultations
252 Téléchargements
