Evaluation design and collection of test data for matching tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Contrat/Projet) Année : 2009
This deliverable presents a systematic procedure for evaluating ontology matching systems and algorithms, in the context of SEALS project. It describes the criteria and metrics on which the evaluations will be carried out and the characteristics of the test data to be used, as well as the evaluation target, which includes the systems generating the alignments for evaluation.
seals-121.pdf (1.68 Mo) Télécharger le fichier
hal-00793455 , version 1 (22-02-2013)
  • HAL Id : hal-00793455 , version 1
Cassia Trojahn dos Santos, Jérôme Euzenat, Christian Meilicke, Heiner Stuckenschmidt. Evaluation design and collection of test data for matching tools. [Contract] 2009, pp.68. ⟨hal-00793455⟩
205 Consultations
272 Téléchargements
