Comparison between ontology distances (preliminary results) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
There are many reasons for measuring a distance between ontologies. In particular, it is useful to know quickly if two ontologies are close or remote before deciding to match them. To that extent, a distance between ontologies must be quickly computable. We present constraints applying to such measures and several possible ontology distances. Then we evaluate experimentally some of them in order to assess their accuracy and speed.
david2008a.pdf (367.03 Ko) Télécharger le fichier
hal-00793534 , version 1 (22-02-2013)
Jérôme David, Jérôme Euzenat. Comparison between ontology distances (preliminary results). Proc. 7th international semantic web conference (ISWC), Oct 2008, Karlsruhe, Germany. pp.245-260, ⟨10.1007/978-3-540-88564-1_16⟩. ⟨hal-00793534⟩
582 Consultations
384 Téléchargements
