Semantic multimedia document adaptation with functional annotations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The diversity of presentation contexts (such as mobile phones, PDAs) for multimedia documents requires the adaptation of document specifications. In an earlier work, we have proposed a semantic adaptation framework for multimedia documents. This framework captures the semantics of the document composition and transforms the relations between multimedia objects according to adaptation constraints. In this paper, we show that capturing only the document composition for adaptation is unsatisfactory because it leads to a limited form of adapted solutions. Hence, we propose to guide adaptation with functional annotations, i.e., annotations related to multimedia objects which express a function in the document. In order to validate this framework, we propose to use RDF descriptions from SMIL documents and adapt such documents with our interactive adaptation prototype.
laborie2009a.pdf (173.16 Ko) Télécharger le fichier
hal-00794919 , version 1 (26-02-2013)
Sébastien Laborie, Jérôme Euzenat, Nabil Layaïda. Semantic multimedia document adaptation with functional annotations. Proc. 4th international workshop on Semantic Media Adaptation and Personalization (SMAP2009), Dec 2009, San Sebastián, Spain. pp.44-49, ⟨10.1109/SMAP.2009.19⟩. ⟨hal-00794919⟩
547 Consultations
105 Téléchargements
