Scalable algorithms for bichromatic line segment intersection problems on coarse grained multicomputers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computational Geometry and Applications Année : 1996
Olivier Devillers
Andreas Fabri
  • Fonction : Auteur
  • PersonId : 833595
We present output-sensitive scalable parallel algorithms for bichromatic line segment intersection problems for the coarse grained multicomputer model. Under the assumption that n≥p^2, where n is the number of line segments and p the number of processors, we obtain an intersection counting algorithm with a time complexity of O( (n log n log p)/p + Ts(n log p,p) ), where Ts(m, p) is the time used to sort m items on a p processor machine. The first term captures the time spent in sequential computation performed locally by each processor. The second term captures the interprocessor communication time. An additional O(k/p) time in sequential computation is spent on the reporting of the k intersections. As the sequential time complexity is O(n log n) for counting and an additional time O(k) for reporting, we obtain a speedup of p/log p in the sequential part of the algorithm. The speedup in the communication part obviously depends on the underlying architecture. For example for a hypercube it ranges between p/log^2p and p/log p depending on the ratio of n and p. As the reporting does not involve more interprocessor communication than the counting, the algorithm achieves a full speedup of p for k≥ O(max(n log n log p, n log^3 p)) even on a hypercube.
Fichier non déposé
hal-00795079 , version 1 (27-02-2013)
Olivier Devillers, Andreas Fabri. Scalable algorithms for bichromatic line segment intersection problems on coarse grained multicomputers. International Journal of Computational Geometry and Applications, 1996, 6 (4), pp.487-506. ⟨10.1142/S0218195996000307⟩. ⟨hal-00795079⟩
53 Consultations
0 Téléchargements
