Model typing for improving reuse in model-driven engineering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Where objects-oriented languages deal with objects as described by classes, model-driven development uses models, as graphs of interconnected objects, described by metamodels.
Steel05a.pdf (202.24 Ko) Télécharger le fichier
hal-00795081 , version 1 (27-02-2013)
  • HAL Id : hal-00795081 , version 1
Jim Steel, Jean-Marc Jézéquel. Model typing for improving reuse in model-driven engineering. Proceedings of MODELS/UML'2005, Oct 2005, Montego Bay, Jamaica. ⟨hal-00795081⟩
95 Consultations
301 Téléchargements
