Toward a generic and extensible merge operator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Merging is a common way to compose both crosscutting and non-crosscutting models. In this paper, we argue that merge can be defined more generically as an operator at the meta-modelling level. By describing merge at this level, a merge operator can be used to compose models based on meta-models other than UML. There are various merge variants and we concede that a full unification of all merge semantics may be infeasible. To define a common merge, we propose the definition of a common merge kernel as a semantic base that can be extended to realise the different expressions of merge.
barais06b.pdf (43.24 Ko) Télécharger le fichier
hal-00795151 , version 1 (27-02-2013)
  • HAL Id : hal-00795151 , version 1
Andrew Jackson, Olivier Barais, Jean-Marc Jézéquel, Siobhán Clarke. Toward a generic and extensible merge operator. Models and Aspects workshop, at ECOOP 2006, Jul 2006, Nantes, France. ⟨hal-00795151⟩
310 Consultations
77 Téléchargements
