Revisiting the Voronoi Description of Protein-Protein Interfaces: Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Describing macro-molecular interfaces is key to improve our understanding of the specificity and of the stability of macro-molecular interactions, and also to predict complexes when little structural information is known. Ideally, an interface model should provide easy-to-compute geometric and topological parameters exhibiting a good correlation with important bio-physical quantities. It should also be parametric and amenable to comparisons. In this spirit, we recently developed an interface model based on Voronoi diagrams, which proved instrumental to refine state-of-the-art conclusions and provide new insights.
This paper formally presents this Voronoi interface model. First, we discuss its connexion to classical interface models based on distance cut-offs and solvent accessibility. Second, we develop the geometric and topological constructions underlying the Voronoi interface, and design efficient algorithms based on the Delaunay triangulation and the α-complex.
We conclude with perspectives. In particular, we expect the Voronoi interface model to be particularly well suited for the problem of comparing interfaces in the context of large-scale structural studies.
voronoi-interfaces-algorithm_prib2010.pdf (240.07 Ko) Télécharger le fichier
hal-00796062 , version 1 (01-03-2013)
Frédéric Cazals. Revisiting the Voronoi Description of Protein-Protein Interfaces: Algorithms. PRIB - 5th IAPR International Conference on Pattern Recognition in Bioinformatics - 2010, Sep 2010, Nijmegen, Netherlands. pp.419-430, ⟨10.1007/978-3-642-16001-1_36⟩. ⟨hal-00796062⟩
Collections
INRIA INRIA2
167 Consultations
207 Téléchargements
