Partitioning, Ordering, and Load Balancing in a Hierarchically Parallel Hybrid Linear Solver - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
PDSLin is a general-purpose algebraic parallel hybrid (direct/iterative) linear solver based on the Schur complement method. The most challenging step of the solver is the computation of a preconditioner based on an approximate global Schur complement. We investigate two combinatorial problems to enhance PDSLin's performance at this step. The first is a multi-constraint partitioning problem to balance the workload while computing the preconditioner in parallel. For this, we describe and evaluate a number of graph and hypergraph partitioning algorithms to satisfy our particular objective and constraints. The second problem is to reorder the sparse right-hand side vectors to improve the data access locality during the parallel solution of a sparse triangular system with multiple right-hand sides. This is to speed up the process of eliminating the unknowns associated with the interface. We study two reordering techniques: one based on a postordering of the elimination tree and the other based on a hypergraph partitioning. To demonstrate the effect of these techniques on the performance of PDSLin, we present the numerical results of solving large-scale linear systems arising from two applications of our interest: numerical simulations of modeling accelerator cavities and of modeling fusion devices.
reportPDSLin.pdf (517.75 Ko) Télécharger le fichier
hal-00797207 , version 1 (06-03-2013)
  • HAL Id : hal-00797207 , version 1
Ichitaro Yamazaki, Xiaoye S. Li, François-Henry Rouet, Bora Uçar. Partitioning, Ordering, and Load Balancing in a Hierarchically Parallel Hybrid Linear Solver. [Research Report] 2011, pp.22. ⟨hal-00797207⟩
247 Consultations
120 Téléchargements
