Improvements on bicriteria pairwise sequence alignment: algorithms and applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioinformatics Année : 2013
Motivation: In this article, we consider the bicriteria pairwise sequence alignment problem and propose extensions of dynamic programming algorithms for several problem variants with a novel pruning technique that efficiently reduces the number of states to be processed. Moreover, we present a method for the construction of phylogenetic trees based on this bicriteria framework. Two exemplary cases are discussed. Results: Numerical results on a real dataset show that this approach is very fast in practice. The pruning technique saves up to 90% in memory usage and 80% in CPU time. Based on this method, phylogenetic trees are constructed from real-life data. In addition of providing complementary information, some of these trees match those obtained by the Maximum Likelihood method. Availability and implementation: Source code is freely available for download at URL http://eden.dei.uc.pt/paquete/MOSAL/, implemented in C and supported on Linux, MAC OS and MS Windows.
abbasi_bioinformatics2013.pdf (1.14 Mo) Télécharger le fichier
hal-00797793 , version 1 (05-05-2023)
Maryam Abbasi, Luis Paquete, Arnaud Liefooghe, Miguel Pinheiro, Pedro Matias. Improvements on bicriteria pairwise sequence alignment: algorithms and applications. Bioinformatics, 2013, 29 (8), pp.996-1003. ⟨10.1093/bioinformatics/btt098⟩. ⟨hal-00797793⟩
245 Consultations
4 Téléchargements
