High order non-conforming multi-element Discontinuous Galerkin method for time domain electromagnetics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics and Computation Année : 2013
We study a high order Discontinuous Galerkin Time Domain (DGTD) method for solving the system of Maxwell equations. This method is formulated on a non-conforming multi-element mesh mixing an unstructured triangulation for the discretization of irregularly shaped objects with a structured (Cartesian) quadrangulation for the rest of the computational domain. Within each element, the electromagnetic field components are approximated by a high order nodal polynomial. The DG method proposed here makes use of a centered scheme for the definition of the numerical traces of the electric and magnetic fields at element interfaces, associated to a second order or fourth order leap-frog scheme for the time integration of the associated semi-discrete equations. We formulate this DGTD method in 3D and study its theoretical properties. In particular, an a priori convergence estimation is elaborated. Finally, we present numerical results for the application of the method to 2D test problems.
RR-8257.pdf (7.18 Mo) Télécharger le fichier
hal-00797973 , version 1 (07-03-2013)
Clement Durochat, Stéphane Lanteri, Claire Scheid. High order non-conforming multi-element Discontinuous Galerkin method for time domain electromagnetics. Applied Mathematics and Computation, 2013, 224, pp.681-704. ⟨10.1016/j.amc.2013.08.069⟩. ⟨hal-00797973⟩
314 Consultations
258 Téléchargements
