A Mechanized Model for CAN Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Formal reasoning on Peer-to-Peer (P2P) systems is an intimidating task. This paper focuses on broadcast algorithms for Content Addressable Network (CAN). Since these algorithms run on top of complex P2P systems, finding the right level of abstraction in order to prove their functional correctness is difficult. This paper presents a mechanized model for both CAN and broadcast protocols over those networks. We demonstrate that our approach is practical by identifying sufficient conditions for a protocol to be correct and efficient. We also prove the existence of a protocol verifying those properties.
main.pdf (424.51 Ko) Télécharger le fichier
hal-00802006 , version 1 (18-03-2013)
  • HAL Id : hal-00802006 , version 1
Francesco Bongiovanni, Ludovic Henrio. A Mechanized Model for CAN Protocols. 16th International Conference on Fundamental Approaches to Software Engineering (FASE'13), Mar 2013, Rome, Italy. ⟨hal-00802006⟩
221 Consultations
196 Téléchargements
