3D model retrieval based on depth line descriptor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper, we propose a novel 2D/3D approach for 3D model matching and retrieving. Each model is represented by a set of depth lines which will be afterward transformed into sequences. The depth sequence information provides a more accurate description of 3D shape boundaries than using other 2D shape descriptors. Retrieval is performed when dynamic programming distance (DPD) is used to compare the depth line descriptors. The DPD leads to an accurate matching of sequences even in the presence of local shifting on the shape. Experimentally, we show absolute improvement in retrieval performance on the Princeton 3D Shape Benchmark database.
chaouchverroustblondeticme07.pdf (315.47 Ko) Télécharger le fichier
hal-00802588 , version 1 (20-03-2013)
Mohamed Chaouch, Anne Verroust-Blondet. 3D model retrieval based on depth line descriptor. ICME 2007 - IEEE International Conference on Multimedia and Expo, Jul 2007, Beijing, China. pp.599 - 602, ⟨10.1109/ICME.2007.4284721⟩. ⟨hal-00802588⟩
Collections
INRIA INRIA2
92 Consultations
209 Téléchargements
