Project Final Report Use and Dissemination of Foreground - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
This document is the final report on use and dissemination of foreground, part of the CONNECT final report. The document provides the lists of: publications, dissemination activities, and exploitable foreground
CONNECT_WP0_Final_Report_Foreground.pdf (295.34 Ko) Télécharger le fichier
hal-00805634 , version 1 (28-03-2013)
  • HAL Id : hal-00805634 , version 1
Emmanuelle Grousset, Valérie Issarny, Antonia Bertolino, Daniela Mulas, Illaria Matteucci, et al.. Project Final Report Use and Dissemination of Foreground. [Research Report] 2012. ⟨hal-00805634⟩
169 Consultations
357 Téléchargements
