C Language Extensions for Hybrid CPU/GPU Programming with StarPU - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
Modern platforms used for high-performance computing (HPC) include machines with both general-purpose CPUs, and "accelerators", often in the form of graphical processing units (GPUs). StarPU is a C library to exploit such platforms. It provides users with ways to define "tasks" to be executed on CPUs or GPUs, along with the dependencies among them, and by automatically scheduling them over all the available processing units. In doing so, it also relieves programmers from the need to know the underlying architecture details: it adapts to the available CPUs and GPUs, and automatically transfers data between main memory and GPUs as needed. While StarPU's approach is successful at addressing run-time scheduling issues, being a C library makes for a poor and error-prone programming interface. This paper presents an effort started in 2011 to promote some of the concepts exported by the library as C language constructs, by means of an extension of the GCC compiler suite. Our main contribution is the design and implementation of language extensions that map to StarPU's task programming paradigm. We argue that the proposed extensions make it easier to get started with StarPU,eliminate errors that can occur when using the C library, and help diagnose possible mistakes. We conclude on future work.
Les plateformes modernes utilisées en calcul intensif (HPC) incluent des machines comprenant à la fois des unités de traitement généralistes (CPU) et des "accélérateurs", souvent sous la forme d'unités de traitement "graphiques" (GPU). StarPU est une bibliothèque C pour programmer sur ces plateformes. Elle fournit aux utilisateurs des moyens de définir des "tâches" pouvant s'exécuter aussi bien sur CPU que sur GPU, ainsi que les dépendances entre ces tâches, et s'occupe de les ordonnancer sur "toutes" les unités de traitement disponibles. Ce faisant, StarPU abstrait le programmeur des détails techniques sous-jacents: StarPU s'adapte aux unités de traitement disponibles et se charge de transférer les données entre elles quand cela est nécessaire. StarPU traite efficacement des problèmes d'ordonnacement, mais l'interface en langage C qu'elle propose est pauvre et facilite les erreurs de programmation. Cet article présente des travaux démarrés en 2011 pour promouvoir certains concepts exposés par la bibliothèque StarPU sous forme d'extensions du langage C, par le biais d'une extensions de la suite de compilateurs GCC. Notre principale contribution est la conception et la mise en œuvre d'extensions du langage C correspondant au paradigme de programmation par tâches de StarPU. Nous montrons que les extensions proposées facilitent la programmation avec StarPU, éliminent des erreurs de programmation pouvant intervenir lorsque la bibliothèque C est utilisée et aident le diagnostique de possibles erreurs. Nous concluons sur les travaux à venir.
RR-8278.pdf (526.96 Ko) Télécharger le fichier
hal-00807033 , version 1 (02-04-2013)
hal-00807033 , version 2 (05-04-2013)
Ludovic Courtès. C Language Extensions for Hybrid CPU/GPU Programming with StarPU. [Research Report] RR-8278, INRIA. 2013, pp.25. ⟨hal-00807033v2⟩
708 Consultations
576 Téléchargements
