Smile Detection Using Multi-scale Gaussian Derivatives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we show that Multi-scale Gaussian Derivatives combined with Support Vector Machines provide an effective approach to facial expression analysis.The approach was tested on the GENKI and Cohn-Kanade dataset for detecting smiles. Our approach outperformed the current benchmark approach of using Gabor Energy Filters with Support Vector Machines.
ELSINA-25.pdf (1017.13 Ko) Télécharger le fichier
hal-00807362 , version 1 (03-04-2013)
  • HAL Id : hal-00807362 , version 1
Varun Jain, James L. Crowley. Smile Detection Using Multi-scale Gaussian Derivatives. 12th WSEAS International Conference on Signal Processing, Robotics and Automation, Feb 2013, Cambridge, United Kingdom. ⟨hal-00807362⟩
604 Consultations
492 Téléchargements
