TCAS software verification using Constraint Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Knowledge Engineering Review Année : 2012
Safety-critical software must be thoroughly verified before being exploited in commercial applications. In particular, any TCAS (Traffic Alert and Collision Avoidance System) implementation must be verified against safety properties extracted from the anti-collision theory that regulates the controlled airspace. This verification step is currently realized with manual code reviews and testing. In our work, we explore the capabilities of Constraint Programming for automated software verification and testing. We built a dedicated constraint solving procedure that combines constraint propagation with linear programming to solve conditional disjunctive constraint systems over bounded integers extracted from computer programs and safety properties. An experience we made on verifying a publicly available TCAS component implementation against a set of safety-critical properties showed that this approach is viable and efficient.
CT4ATCgotlieb.pdf (230.18 Ko) Télécharger le fichier
hal-00807905 , version 1 (04-04-2013)
  • HAL Id : hal-00807905 , version 1
A. Gotlieb. TCAS software verification using Constraint Programming. Knowledge Engineering Review, 2012, 27 (3), pp.343--360. ⟨hal-00807905⟩
137 Consultations
1430 Téléchargements
