A hierarchy of heuristic-based models of crowd dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Kinetic and Related Models Année : 2013
We derive a hierarchy of kinetic and macroscopic models from a noisy variant of the heuristic behavioral Individual-Based Model of Moussaid et al, PNAS 2011, where the pedestrians are supposed to have constant speeds. This IBM supposes that the pedestrians seek the best compromise between navigation towards their target and collisions avoidance. We first propose a kinetic model for the probability distribution function of the pedestrians. Then, we derive fluid models and propose three different closure relations. The first two closures assume that the velocity distribution functions are either a Dirac delta or a von Mises-Fisher distribution respectively. The third closure results from a hydrodynamic limit associated to a Local Thermodynamical Equilibrium. We develop an analogy between this equilibrium and Nash equilibia in a game theoretic framework. In each case, we discuss the features of the models and their suitability for practical use.
Heuristic_130405.pdf (436.74 Ko) Télécharger le fichier
hal-00808691 , version 1 (05-04-2013)
Pierre Degond, Cécile Appert-Rolland, Mehdi Moussaid, Julien Pettré, Guy Theraulaz. A hierarchy of heuristic-based models of crowd dynamics. Kinetic and Related Models , 2013, 6, pp.809-839. ⟨10.1007/s10955-013-0805-x⟩. ⟨hal-00808691⟩
670 Consultations
300 Téléchargements
