3D face reconstruction in a binocular passive stereoscopic system using face properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we introduce a novel approach for face stereo reconstruction in passive stereo vision system. Our approach is based on the generation of a facial disparity map, requiring neither expensive devices nor generic face models. It consists of incorporating face properties in the disparity estimation to enhance the 3D face reconstruction in real time application. An algorithm based on the Active Shape Model (ASM) is proposed to acquire 3D sparse estimation of the face with a high confidence. Using sparse estimation as guidance and considering the face symmetry and smoothness, the dense disparity is completed. Experimental results are presented to demonstrate the reconstruction accuracy of the proposed method.
aissaoui123d.pdf (681.79 Ko) Télécharger le fichier
hal-00812273 , version 1 (29-09-2018)
Amel Aissaoui, Jean Martinet, Chaabane Djeraba. 3D face reconstruction in a binocular passive stereoscopic system using face properties. International Conference on Image Processing (ICIP) 2012, Sep 2012, Orlando, FL, United States. pp.1789-1792, ⟨10.1109/ICIP.2012.6467228⟩. ⟨hal-00812273⟩
321 Consultations
365 Téléchargements
