Drowsy Driver Detection System Using Eye Blink Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an automatic drowsy driver monitoring and accident prevention system that is based on monitoring the changes in the eye blink duration. Our proposed method detects visual changes in eye locations using the proposed horizontal symmetry feature of the eyes. Our new method detects eye blinks via a standard webcam in real-time at 110fps for a 320×240 resolution. Experimental results in the JZU [3] eye-blink database showed that the proposed system detects eye blinks with a 94% accuracy with a 1% false positive rate.
drowsy driver detection system using eye blinking patterns.pdf (231.71 Ko) Télécharger le fichier
hal-00812315 , version 1 (28-09-2018)
Taner Danisman, Ioan Marius Bilasco, Chaabane Djeraba, Nacim Ihaddadene. Drowsy Driver Detection System Using Eye Blink Patterns. International Conference on Machine and Web Intelligence (ICMWI 2010), Oct 2010, Alger, Algeria. pp.230-233, ⟨10.1109/ICMWI.2010.5648121⟩. ⟨hal-00812315⟩
430 Consultations
4119 Téléchargements
