3D Face reconstruction in a binocular passive stereoscopic system using face properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Amel Aissaoui
  • Fonction : Auteur correspondant
  • PersonId : 184167
  • IdHAL : amel-aissaoui
Connectez-vous pour contacter l'auteur
We present a novel approach for face stereo reconstruction in passive stereo vision system. Our approach is based on the generation of a facial disparity map, requiring neither expensive devices nor generic face models. It consists of incorporating face properties in the disparity estimation to enhance the 3D face reconstruction. An algorithm based on the Active Shape Model (ASM) is proposed to acquire 3D sparse estimation of the face with a high confidence. Using sparse estimation as guidance and considering the face symmetry and smoothness, the dense disparity is completed. Experimental results demonstrate the reconstruction accuracy of the proposed method.
Fichier non déposé
hal-00812472 , version 1 (12-04-2013)
  • HAL Id : hal-00812472 , version 1
Amel Aissaoui. 3D Face reconstruction in a binocular passive stereoscopic system using face properties. 7th Multitel Spring workshop on video analysis, Jun 2012, Mons, Belgium. ⟨hal-00812472⟩
97 Consultations
0 Téléchargements
