Horizontal Data Fusion for Integrative Modelling: the MedINRIA Fusion Toolbox - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2010
The aim of our project at INRIA within the Virtual Physiological Human Network of Excellence is to provide a toolbox enabling the visualisation and the aggregation of data fusion tools and algorithms: Medinria-fusion . Through the use of a core/plug-ins architecture, it explores solutions to make it easy for researchers to import their own tools, wrap them around a single application or exchange them between applications supporting the same framework. That attempt at a universal solution is a step towards standardisation of the exchange of algorithms. Standardisation calls for sustainability, maintainability. The proposed framework can also help quantitative and qualitative tests of functionally similar methods. Medinria-fusion is a demonstrator that implements a registration algorithm, using the API we propose as an open framework. This software allows to visualise several formats of images (among them is DICOM).
noe-abstract.pdf (239.05 Ko) Télécharger le fichier
hal-00813764 , version 1 (17-04-2013)
  • HAL Id : hal-00813764 , version 1
Benoît Bleuzé, Olivier Clatz, Pierre Fillard, Maxime Sermesant, Nicolas Toussaint, et al.. Horizontal Data Fusion for Integrative Modelling: the MedINRIA Fusion Toolbox. 2010. ⟨hal-00813764⟩
333 Consultations
106 Téléchargements
