A Goodness-of-fit Test for the Distribution Tail - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2007
In order to check that a parametric model provides acceptable tail approximations, we present a test which compares the parametric estimate of an extreme upper quantile with its semiparametric estimate obtained by extreme value theory. To build this test, the sampling variations of these estimates are approximated through parametric bootstrap. Numerical Monte Carlo simulations explore the covering probability and power of the test. A real-data study illustrates these results.
testGPD2.pdf (167.13 Ko) Télécharger le fichier
hal-00814959 , version 1 (18-04-2013)
  • HAL Id : hal-00814959 , version 1
  • PRODINRA : 289937
Jean Diebolt, Myriam Garrido, Stéphane Girard. A Goodness-of-fit Test for the Distribution Tail. M. Ahsanullah and S.N.U.A. Kirmani. Topics in Extreme Values, Nova Science, New-York, pp.95-109, 2007, 978-1600217142. ⟨hal-00814959⟩
473 Consultations
1659 Téléchargements
