Access Control for HTTP Operations on Linked Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Access control is a recognized open issue when interacting with RDF using HTTP methods. In literature, authentication and authorization mechanisms either introduce undesired complexity such as SPARQL and ad-hoc policy languages, or rely on basic access control lists, thus resulting in limited policy expressiveness. In this paper we show how the Shi3ld attribute-based authorization framework for SPARQL endpoints has been progressively converted to protect HTTP operations on RDF. We proceed by steps: we start by supporting the SPARQL 1.1 Graph Store Protocol, and we shift towards a SPARQL-less solution for the Linked Data Platform. We demonstrate that the resulting authoriza- tion framework provides the same functionalities of its SPARQL-based counterpart, including the adoption of Semantic Web languages only.
Web
eswc2013_shi3ld.pdf (588.63 Ko) Télécharger le fichier
hal-00815067 , version 1 (18-04-2013)
  • HAL Id : hal-00815067 , version 1
Luca Costabello, Serena Villata, Oscar Rodriguez Rocha, Fabien Gandon. Access Control for HTTP Operations on Linked Data. ESWC - 10th Extended Semantic Web Conference - 2013, May 2013, Montpellier, France. ⟨hal-00815067⟩
323 Consultations
898 Téléchargements
