Tight Performance Bounds for Approximate Modified Policy Iteration with Non-Stationary Policies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Boris Lesner
  • Fonction : Auteur
  • PersonId : 933391
Bruno Scherrer
We consider approximate dynamic programming for the infinite-horizon stationary $\gamma$-discounted optimal control problem formalized by Markov Decision Processes. While in the exact case it is known that there always exists an optimal policy that is stationary, we show that when using value function approximation, looking for a non-stationary policy may lead to a better performance guarantee. We define a non-stationary variant of MPI that unifies a broad family of approximate DP algorithms of the literature. For this algorithm we provide an error propagation analysis in the form of a performance bound of the resulting policies that can improve the usual performance bound by a factor $O\left(1-\gamma\right)$, which is significant when the discount factor $\gamma$ is close to 1. Doing so, our approach unifies recent results for Value and Policy Iteration. Furthermore, we show, by constructing a specific deterministic MDP, that our performance guarantee is tight.
report.pdf (570.15 Ko) Télécharger le fichier
hal-00815996 , version 1 (19-04-2013)
Boris Lesner, Bruno Scherrer. Tight Performance Bounds for Approximate Modified Policy Iteration with Non-Stationary Policies. 2013. ⟨hal-00815996⟩
179 Consultations
229 Téléchargements
