Component reconfiguration in the presence of conflicts. Technical report of the Aeolus project - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2013
Components are traditionally modeled as black-boxes equipped with interfaces that indicate provided/required ports and, often, also conflicts with other components that cannot coexist with them. In modern tools for automatic system management, components become grey-boxes that show relevant internal states and the possible actions that can be acted on the components to change such state during the deployment and reconfiguration phases. However, state-of-the-art tools in this field do not support a systematic management of conflicts. In this paper we investigate the impact of conflicts by precisely characterizing the increment of complexity on the reconfiguration problem.
icalp-2013.pdf (307.7 Ko) Télécharger le fichier
hal-00816468 , version 1 (22-04-2013)
  • HAL Id : hal-00816468 , version 1
Roberto Di Cosmo, Jacopo Mauro, Stefano Zacchiroli, Gianluigi Zavattaro. Component reconfiguration in the presence of conflicts. Technical report of the Aeolus project. 2013. ⟨hal-00816468⟩
560 Consultations
114 Téléchargements
