On the use of perfectly matched layers in the presence of long or backward propagating guided elastic waves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Wave Motion Année : 2014
An efficient method to compute the scattering of a guided wave by a localized defect, in an elastic waveguide of infinite extent and bounded cross section, is considered. It relies on the use of perfectly matched layers (PML) to reduce the problem to a bounded portion of the guide, allowing for a classical finite element discretization. The difficulty here comes from the existence of backward propagating modes, which are not correctly handled by the PML. We propose a simple strategy, based on finite-dimensional linear algebra arguments and using the knowledge of the modes, to recover a correct approximation to the solution with a low additional cost compared to the standard PML approach. Numerical experiments are presented in the two-dimensional case involving Rayleigh--Lamb modes.
preprint_v2.pdf (21.38 Mo) Télécharger le fichier
hal-00816895 , version 1 (23-04-2013)
hal-00816895 , version 2 (18-07-2013)
Anne-Sophie Bonnet-Ben Dhia, Colin Chambeyron, Guillaume Legendre. On the use of perfectly matched layers in the presence of long or backward propagating guided elastic waves. Wave Motion, 2014, 51 (2), pp.266-283. ⟨10.1016/j.wavemoti.2013.08.001⟩. ⟨hal-00816895v2⟩
529 Consultations
299 Téléchargements
