Simple simpl - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Simple simpl
We report on a new implementation of a reduction strategy in Coq to simplify terms during interactive proofs. By "simplify", we mean to reduce terms as much as possible while avoid- ing to make them grow in size. Reaching this goal amounts to a discussion about how not to unfold uselessly global constants. Coq's simpl is such a reduction strategy and the current paper describes an alternative more efficient abstract-machine-based implementation to it
ITP13_Boutillier.pdf (110.91 Ko) Télécharger le fichier
hal-00816918 , version 1 (23-04-2013)
  • HAL Id : hal-00816918 , version 1
Pierre Boutillier. Simple simpl. 2013. ⟨hal-00816918⟩
727 Consultations
284 Téléchargements
