Analysis of knowledge transformation and merging techniques and implementations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Contrat/Projet) Année : 2007
Dealing with heterogeneity requires finding correspondences between ontologies and using these correspondences for performing some action such as merging ontologies, transforming ontologies, translating data, mediating queries and reasoning with aligned ontologies. This deliverable considers this problem through the introduction of an alignment life cycle which also identifies the need for manipulating, storing and sharing the alignments before processing them. In particular, we also consider support for run time and design time alignment processing.
kweb-227.pdf (668.64 Ko) Télécharger le fichier
hal-00817814 , version 1 (25-04-2013)
  • HAL Id : hal-00817814 , version 1
François Scharffe, Jérôme Euzenat, Chan Le Duc, Pavel Shvaiko. Analysis of knowledge transformation and merging techniques and implementations. [Contract] 2007, pp.50. ⟨hal-00817814⟩
276 Consultations
300 Téléchargements
