A fast and Efficient Subpixelic Edge Detector - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1993
Frédéric Devernay
In this article we present a two dimensional edge extractor which gives the edge position in an image with a subpixelic precision. The method presented here gives a good accuracy with a low computational cost, and its implementation is very simple since it is derivated from the well-known Non-Maxima Suppression method [I, 3]. We also justify the method by showing that it gives the exact result in a theoretical one dimensional example. We have tested the edge extractor on several synthetical and real images and the results are reported in this paper.
devernay-orasis93.pdf (922.73 Ko) Télécharger le fichier
hal-00818241 , version 1 (26-04-2013)
  • HAL Id : hal-00818241 , version 1
Frédéric Devernay. A fast and Efficient Subpixelic Edge Detector. Quatrièmes Journées Orasis, 1993, Mulhouse, France. ⟨hal-00818241⟩
Collections
INRIA INRIA2
149 Consultations
308 Téléchargements
