Avoiding Moving Obstacles during Visual Navigation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Moving obstacle avoidance is a fundamental requirement for any robot operating in real environments, where pedestrians, bicycles and cars are present. In this work, we design and validate a new approach that takes explicitly into account obstacle velocities, to achieve safe visual navigation in outdoor scenarios. A wheeled vehicle, equipped with an actuated pinhole camera and with a lidar, must follow a path represented by key images, without colliding with the obstacles. To estimate the obstacle velocities, we design a Kalman-based observer. Then, we adapt the tentacles designed in [1], to take into account the predicted obstacle positions. Finally, we validate our approach in a series of simulated and real experiments, showing that when the obstacle velocities are considered, the robot behaviour is safer, smoother, and faster than when it is not.
2013_icra_cherubini-avoiding_moving_obstacles_during_visual_navigation.pdf (2.05 Mo) Télécharger le fichier
lirmm-00808317 , version 1 (05-04-2013)
  • HAL Id : lirmm-00808317 , version 1
Andrea Cherubini, Boris Grechanichenko, Fabien Spindler, François Chaumette. Avoiding Moving Obstacles during Visual Navigation. ICRA: International Conference on Robotics and Automation, May 2013, Karlsruhe, Germany. pp.3054-3059. ⟨lirmm-00808317⟩
594 Consultations
483 Téléchargements
