Comparison of index-2 and index-1 DAE solvers for nonsmooth multibody systems with unilateral or bilateral constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The aim of this work is to study some numerical solvers for the integration of index-1 and index-2 differential algebraic equations that describe the dynamics of constrained mechanical systems, in the framework of event-driven schemes. These solvers will be compared in terms of drift of the constraints, implementation and the way they handle cases when the constraints are not sufficiently differentiable.
acte_CSMA2013_convMod.pdf (377.4 Ko) Télécharger le fichier
hal-00821315 , version 2 (09-05-2013)
hal-00821315 , version 1 (28-10-2017)
  • HAL Id : hal-00821315 , version 2
Mounia Haddouni, Vincent Acary, Jean-Daniel Beley, Stéphane Garreau. Comparison of index-2 and index-1 DAE solvers for nonsmooth multibody systems with unilateral or bilateral constraints. CSMA 2013 - 11e Colloque National en Calcul des Structures, CSMA, May 2013, Giens, France. ⟨hal-00821315v2⟩
376 Consultations
693 Téléchargements
