Expressive alignment language and implementation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Contrat/Projet) Année : 2007
This deliverable provides the description of an alignment language which is both expressive and independent from ontology languages. It defines the language through its abstract syntax and semantics depending on ontology language semantics. It then describes two concrete syntax: an exchange syntax in RDF/XML and a surface syntax for human consumption. Finally, it presents the current implementation of this expressive language within the Alignment API taking advantage of the OMWG implementation.
kweb-2210.pdf (306.18 Ko) Télécharger le fichier
hal-00822892 , version 1 (15-05-2013)
  • HAL Id : hal-00822892 , version 1
Jérôme Euzenat, François Scharffe, Antoine Zimmermann. Expressive alignment language and implementation. [Contract] 2007, pp.60. ⟨hal-00822892⟩
343 Consultations
313 Téléchargements
