Results of the Ontology Alignment Evaluation Initiative 2007 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We present the Ontology Alignment Evaluation Initiative 2007 campaign as well as its results. The OAEI campaign aims at comparing ontology matching systems on precisely defined test sets. OAEI-2007 builds over previous campaigns by having 4 tracks with 7 test sets followed by 17 participants. This is a major increase in the number of participants compared to the previous years. Also, the evaluation results demonstrate that more participants are at the forefront. The final and official results of the campaign are those published on the OAEI web site.
paper9.pdf (426.83 Ko) Télécharger le fichier
hal-00822893 , version 1 (15-05-2013)
  • HAL Id : hal-00822893 , version 1
Jérôme Euzenat, Antoine Isaac, Christian Meilicke, Pavel Shvaiko, Heiner Stuckenschmidt, et al.. Results of the Ontology Alignment Evaluation Initiative 2007. Proc. 2nd ISWC 2007 international workshop on ontology matching (OM), Nov 2007, Busan, South Korea. pp.96-132. ⟨hal-00822893⟩
404 Consultations
220 Téléchargements
