Towards a principled approach to semantic interoperability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Semantic interoperability is the faculty of interpreting knowledge imported from other languages at the semantic level, i.e. to ascribe to each imported piece of knowledge the correct interpretation or set of models. It is a very important requirement for delivering a worldwide semantic web. This paper presents preliminary investigations towards developing a unified view of the problem. It proposes a definition of semantic interoperability based on model theory and shows how it applies to already existing works in the domain. Then, new applications of this definition to family of languages, ontology patterns and explicit description of semantics are presented.
euzenat.pdf (79.1 Ko) Télécharger le fichier
hal-00822909 , version 1 (15-05-2013)
  • HAL Id : hal-00822909 , version 1
Jérôme Euzenat. Towards a principled approach to semantic interoperability. Proc. IJCAI 2001 workshop on ontology and information sharing, Aug 2001, Seattle, United States. pp.19-25. ⟨hal-00822909⟩
593 Consultations
575 Téléchargements
