Computing class polynomials for abelian surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Experimental Mathematics Année : 2014
We describe a quasi-linear algorithm for computing Igusa class polynomials of Jacobians of genus 2 curves via complex floating-point approximations of their roots. After providing an explicit treatment of the computations in quartic CM fields and their Galois closures, we pursue an approach due to Dupont for evaluating ϑ- constants in quasi-linear time using Newton iterations on the Borchardt mean. We report on experiments with our implementation and present an example with class number 20016.
cm2.pdf (344.43 Ko) Télécharger le fichier
hal-00823745 , version 1 (17-05-2013)
hal-00823745 , version 2 (09-12-2013)
Andreas Enge, Emmanuel Thomé. Computing class polynomials for abelian surfaces. Experimental Mathematics, 2014, 23 (2), pp.129-145. ⟨10.1080/10586458.2013.878675⟩. ⟨hal-00823745v2⟩
909 Consultations
328 Téléchargements
