Global stabilization of the chemostat with delayed and sampled measurements and control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The classical model of the chemostat with one substrate, one species and a Haldane type growth rate function is considered. The input substrate concentration is supposed to be constant and the dilution rate is considered as the control. The problem of asymptotically stabilizing an equilibrium point of this system in the case where the measured concentrations are delayed and piecewise constant with a piecewise constant control is addressed.
Automatique
ifacafterrev.pdf (154 Ko) Télécharger le fichier
hal-00823970 , version 1 (20-05-2013)
  • HAL Id : hal-00823970 , version 1
  • PRODINRA : 315902
Frédéric Mazenc, Jérôme Harmand, Hugues Mounier. Global stabilization of the chemostat with delayed and sampled measurements and control. 9th IFAC Symposium on Nonlinear Control Systems (NOLCOS 2013), Sep 2013, Toulouse, France. ⟨hal-00823970⟩
350 Consultations
86 Téléchargements
