On the integration of differential fractions
In this paper, we provide a differential algebra algorithm for integrating fractions of differential polynomials. It is not restricted to differential fractions that are the derivatives of other differential fractions. The algorithm leads to new techniques for representing differential fractions, which may help converting differential equations to integral equations (as for example used in parameter estimation).
