Three semantics for distributed systems and their relations with alignment composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
An ontology alignment explicitly describes the relations holding between two ontologies. A system composed of ontologies and alignments interconnecting them is herein called a distributed system. We give three different semantics of a distributed system, that do not interfere with the semantics of ontologies. Their advantages are compared, with respect to allowing consistent merge of ontologies, managing heterogeneity and complying with an alignment composition operation. We show that only the two first variants, which differ from other proposed semantics, can offer a sound composition operation.
zimmermann2006b.pdf (212.61 Ko) Télécharger le fichier
hal-00825950 , version 1 (24-05-2013)
Antoine Zimmermann, Jérôme Euzenat. Three semantics for distributed systems and their relations with alignment composition. Proc. 5th International semantic web conference (ISWC), Nov 2006, Athens, United States. pp.16-29, ⟨10.1007/11926078_2⟩. ⟨hal-00825950⟩
752 Consultations
584 Téléchargements
