A Balance Equation Determines a Switch in Neuronal Excitability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS Computational Biology Année : 2013
We use the qualitative insight of a planar neuronal phase portrait to detect an excitability switch in arbitrary conductance based models from a simple mathematical condition. The condition expresses a balance between ion channels that provide a negative feedback at resting potential (restorative channels) and those that provide a positive feedback at resting potential (regenerative channels). Geometrically, the condition imposes a transcritical bifurcation that rules the switch of excitability through the variation of a single physiological parameter. Our analysis of six different published conductance based models always finds the transcritical bifurcation and the associated switch in excitability, which suggests that the mathematical predictions have a physiological relevance and that a same regulatory mechanism is potentially involved in the excitability and signaling of many neurons.
Franci2013.pdf (1.84 Mo) Télécharger le fichier
hal-00826259 , version 1 (27-05-2013)
Alessio Franci, Guillaume Drion, Vincent Seutin, Rodolphe Sepulchre. A Balance Equation Determines a Switch in Neuronal Excitability. PLoS Computational Biology, 2013, 9 (5), pp.e1003040. ⟨10.1371/journal.pcbi.1003040⟩. ⟨hal-00826259⟩
176 Consultations
156 Téléchargements
