Predictive Control for Trajectory Tracking and Decentralized Navigation of Multi-Agent Formations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Applied Mathematics and Computer Science Année : 2013
This paper addresses a predictive control strategy for a particular class of multi-agent formations with a time-varying topology. The goal is to guarantee tracking capabilities with respect to a reference trajectory which is pre-specified for an agent designed as the leader. Then, the rest of the agents, designed as followers, track the position and orientation of the leader. In real-time, a predictive control strategy enhanced with the Potential Field methodology is used in order to derive a feedback control action based only on local information within the group of agents. The main concern is that the interconnections between the agents are time-varying, affecting the neighborhood around each agent. The proposed method exhibits effective performance validated through some illustrative examples.
J_AMCS.pdf (682.5 Ko) Télécharger le fichier
hal-00826632 , version 1 (16-03-2020)
Ionela Prodan, Sorin Olaru, Cristina Stoica, Silviu-Iulian Niculescu. Predictive Control for Trajectory Tracking and Decentralized Navigation of Multi-Agent Formations. International Journal of Applied Mathematics and Computer Science, 2013, 23 (1), pp.91-102. ⟨10.2478/amcs-2013-0008⟩. ⟨hal-00826632⟩
331 Consultations
70 Téléchargements
