Modélisation du mercure, du plomb et du cadmium à l'échelle européenne - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pollution Atmosphérique : climat, santé, société Année : 2006
Since its adoption in 1979, the Convention on Long-Range Transboundary Air Pollution has addressed some of the major environmental problems of the UNECE region. In this framework the protocol on heavy metals, signed in 1998, gives first priority to lead (Pb), cadmium (Cd) and mercury (Hg). These heavy metals and their compounds are highly toxic substances, being likely to bio-accumulate in organisms. Understanding and modelling their transport and fate in the atmosphere allow to take more effective decision to reduce their impact on the ecosystems. POLAIR 3D is a three-dimensional chemistry-transport model developed within the modelling system POLYPHEMUS at CEREA. It is designed to handle a wide range of applications from passive transport to photo-chemistry and aerosol modelling, and has been recently extended to deal with heavy metals at European scale. Removal processes have been carefully taken into account since deposition fluxes are more worrying than air concentrations. Most of the heavy metals in the atmosphere have a passive chemical behaviour but are carried by the aerosol phase. For this reason their rate of removal are linked to those of aerosol particles. Mercury differs because of its high saturated vapour pressure and mainly being found under gaseous elemental form. However it is essential to simulate mercury chemistry in gaseous and aqueous phases since oxidised mercury species represent the main part of the deposited mercury mass. Simulated air concentrations and deposition fluxes are evaluated by comparison to data of the EMEP measurement network. Sensitivity analysis has been performed using adjoint techniques. Such investigation being required to handle in a suitable way our developed model. Moreover, these techniques allow to carry out inverse modelling to improve boundary conditions which are crucial with a restricted area model.
Le mercure, le plomb et le cadmium sont actuellement un objet de préoccupations pour les instances concernées par la pollution atmosphérique. La dénomination commune de " métaux lourds " cache en fait des comportements variables de ces composés dans l'atmosphère qui influencent fortement leur transfert vers les écosystèmes. La modélisation numérique de ces comportements doit permettre de mieux comprendre leur devenir, une attention particulière devant être portée aux processus de déposition. L'utilisation pertinente d'un modèle numérique ne peut se faire sans étudier sa sensibilité aux données et paramètres qu'il utilise. Des techniques ont été développées en ce sens puis appliquées au modèle de chimie-transport POLAIR 3D. Elles permettent par ailleurs de mener à bien un travail de modélisation inverse.
Fichier non déposé
hal-00826909 , version 1 (28-05-2013)
  • HAL Id : hal-00826909 , version 1
Yelva Roustan, Marc Bocquet, Luc Musson-Genon, Bruno Sportisse. Modélisation du mercure, du plomb et du cadmium à l'échelle européenne. Pollution Atmosphérique : climat, santé, société, 2006, 48 (191), pp.317-327. ⟨hal-00826909⟩
199 Consultations
0 Téléchargements
