The auxin signalling network translates dynamic input into robust patterning at the shoot apex - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Molecular Systems Biology Année : 2011
Teva Vernoux
Valérie Morin
  • Fonction : Auteur
  • PersonId : 940697
Mark Estelle
Jan Traas
  • Fonction : Auteur
  • PersonId : 1202606
The plant hormone auxin is thought to provide positional information for patterning during development. It is still unclear, however, precisely how auxin is distributed across tissues and how the hormone is sensed in space and time. The control of gene expression in response to auxin involves a complex network of over 50 potentially interacting transcriptional activators and repressors, the auxin response factors (ARFs) and Aux/IAAs. Here, we perform a large-scale analysis of the Aux/IAA-ARF pathway in the shoot apex of Arabidopsis, where dynamic auxin-based patterning controls organogenesis. A comprehensive expression map and full interactome uncovered an unexpectedly simple distribution and structure of this pathway in the shoot apex. A mathematical model of the Aux/IAA-ARF network predicted a strong buffering capacity along with spatial differences in auxin sensitivity. We then tested and confirmed these predictions using a novel auxin signalling sensor that reports input into the signalling pathway, in conjunction with the published DR5 transcriptional output reporter. Our results provide evidence that the auxin signalling network is essential to create robust patterns at the shoot apex.
msb201139.pdf (4.5 Mo) Télécharger le fichier
Format : Figure, Image
hal-00828880 , version 1 (31-05-2013)
Paternité
Teva Vernoux, Géraldine Brunoud, Etienne Farcot, Valérie Morin, Hilde van Den Daele, et al.. The auxin signalling network translates dynamic input into robust patterning at the shoot apex. Molecular Systems Biology, 2011, 7 (508), ⟨10.1038/msb.2011.39⟩. ⟨hal-00828880⟩
7825 Consultations
1056 Téléchargements
