Une nouvelle sémantique pour la programmation logique capturant la sémantique des modèles stables : la sémantique des extensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Answer set programming is a well studied framework in logic programming. Many research works had been done in order to de ne a semantics for logic programs. Most of these semantics are iterated xed point semantics. The main idea is the canonical model approach which is a declarative semantics for logic programs that can be de ned by selecting for each program one of its canonical models. The notion of canonical models of a logic program is what it is called the stable models. The stable models of a logic program are in a certain sense the minimal Herbrand models of its "reduct" programs. Here we introduce a new semantics for logic programs that is di erent from the known xed point semantics. In our approach, logic programs are expressed as CNF formulas (sets of clauses) of a propositional logic for which we de ne a notion of extension. We prove in this semantics, that each consistent CNF formula admits at least an extension and for each given stable model of a logic program there exists an extension of its corresponding CNF formula which logically entails it. On the other hand, we show that some of the extensions do not entail any stable model, in this case, we de ne a simple descrimination condition which allows to recognize such extensions. These extensions could be very important, but are not captured by the stable models semantics. Our approach, extends the stable model semantics in this sense. Following the new semantics, we give a full characterization of the stable models of a logic program by means of the extensions of its CNF encoding verifying a simple condition, and provide a procedure which can be used to compute such extensions from which we deduce the stable models of the given logic program.
La programmation par ensembles r éponses (Answer Set Programming) est un cadre bien étudi é en programmation logique. Plusieurs travaux ont été faits pour d éfinir une s émantique pour les programmes logiques. La plupart de ces s émantiques sont en fait des s émantiques de point fi xe. L'id ée principale est le calcul de mod èles canoniques du programme logique consid ér é, appel és mod èles stables. Les mod èles stables sont dans un certain sens des mod èles minimaux des programmes r éduits. Nous introduisons une nouvelle s emantique pour les programmes logiques, à partir d'une notion d'extension d'une formule propositionnelle classique. Ces extensions peuvent être calcul és de mani ère it érative. Un programme logique est alors cod é par un ensemble de clauses de la logique propositionnelle. On prouve que chaque formule consistante admet au moins une extension et que, pour chaque mod èle stable d'un programme logique, il existe une extension de son codage qui l'implique logiquement. Certaines des extensions ne correspondent pas à un mod èle stable mais sont int eréssantes. Nous donnons une condition discriminante simple qui permet de reconnaitre de telles extensions. En fin, nous d écrivons un algorithme qui calcule les extensions de la formule CNF codant le programme logique. De cet ensemble d'extension on peut extraire les mod èles stables du programme logique initial.
paper_31.pdf (215.97 Ko) Télécharger le fichier
hal-00829608 , version 1 (03-06-2013)
  • HAL Id : hal-00829608 , version 1
Belaïd Benhamou, Pierre Siegel. Une nouvelle sémantique pour la programmation logique capturant la sémantique des modèles stables : la sémantique des extensions. Huitièmes Journées Francophones de Programmation par Contraintes - JFPC 2012, May 2012, Toulouse, France. ⟨hal-00829608⟩
303 Consultations
149 Téléchargements
