Phenotyping progenies for complex architectural traits: a strategy for 1-year-old apple trees (Malus x domestica Borkh.) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Tree Genetics and Genomes Année : 2006
The aim of this study was to define a methodology for describing architectural traits in a quantitative way on tree descendants. Our strategy was to collect traits related to both tree structural organization, resulting from growth and branching, and tree form and then to select among these traits relevant descriptors on the basis of their genetic parameters. Because the complexity of tree architecture increases with tree age, we chose to describe the trees in the early stages of development. The study was carried out on a 1-year-old apple progeny derived from two parent cultivars with contrasted architecture. A large number of variables were collected at different positions and scales within the trees. Broad-sense heritability and genetic correlations were estimated and the within tree variability was analyzed for variables measured on long sylleptic axillary shoots (LSAS). These results were combined to select heritable and not correlated variables. Finally, the selection of variables proposed combines topological with geometric traits measured on both trunks and LSAS: (1) on the trunk, mean internode length, and number of sylleptic axillary shoots; (2) on axillary shoots, conicity, bending, and number of sylleptic axillary shoots born at order 3. The trees of the progeny were partitioned on the basis of these variables. The putative agronomic interest of the selected variables with respect to the subsequent tree development is discussed.
Segura_etal_TGG06_preprint.pdf (246.87 Ko) Télécharger le fichier
Format : Figure, Image
hal-00830066 , version 1 (04-06-2013)
Vincent Segura, Christian Cilas, François Laurens, Evelyne Costes. Phenotyping progenies for complex architectural traits: a strategy for 1-year-old apple trees (Malus x domestica Borkh.). Tree Genetics and Genomes, 2006, 2 (3), pp.140-151. ⟨10.1007/s11295-006-0037-1⟩. ⟨hal-00830066⟩
280 Consultations
386 Téléchargements
