Computational methods for hidden Markov tree models - An application to wavelet trees.
The hidden Markov tree models were introduced by Crouse et al. in 1998 for modeling nonindependent, non-Gaussian wavelet transform coefficients. In their paper, they developed the equivalent of the forward-backward algorithm for hidden Markov tree models and called it the 'upward-downward algorithm'. This algorithm is subject to the same numerical limitations as the forward-backward algorithm for hidden Markov chains (HMCs). In this paper, adapting the ideas of Devijver from 1985, we propose a new 'upward-downward' algorithm, which is a true smoothing algorithm and is immune to numerical underflow. Furthermore, we propose a Viterbi-like algorithm for global restoration of the hidden state tree. The contribution of those algorithms as diagnosis tools is illustrated through the modeling of statistical dependencies between wavelet coefficients with a special emphasis on local regularity changes.
Modélisation et simulation
